Old                07-13-2004, 4:46 PM Reply
i need help on 360s i just cnat grab the handel i laways miss it what am i doing wrong??
Old    Chris W (weygone)      Join Date: Jun 2004       07-13-2004, 4:55 PM Reply
make sure youre pulling the rope in towards your trailing hip. i used to not pull in very hard and the handle was too far away for me to grab it with my other hand but once i started pulling the rope in towards my hip i didnt have any prblem
Old    Matt (pittsy)      Join Date: Apr 2004       07-13-2004, 6:55 PM Reply
do a FS 3 and land it wrapped witht the handle behind your back and then just pass it to your front hand after you land
Old                07-13-2004, 9:36 PM Reply
Thanks chris
Matt the problem wiht that is i cant figuour out how to wrap the handel around.
Old    Matt (pittsy)      Join Date: Apr 2004       07-13-2004, 11:16 PM Reply
Tanner,
you can either do a HS or TS FS 3 make sure you spin FS so you can land wrapped, what you do is you go up the wake wait to the pop then let go with your front hand and pull with your back hand and then just keep holding the handle and your arm will go the small of your back in which you can pass it after you. you can practice by put the part of your handle where it connects to your rope on your tower then you just rotate with just your back hand and learn how to land it wrapped after being able to do these then you can start to learn to pass the handle earlier.
Old                07-14-2004, 10:09 AM Reply
Thanks Matt i will try them today
