Douglas, your problem most likely is cause by your cut, not your rope position. You need to make sure that you make an abrupt enough edge change so that your shoulders are square to the wake on takeoff. it sounds to me that you aren't square so you are throwing the flip a little backwards rather than in the direction of the second wake. Try to exxaggerate your edge change and square up to the wake, and you will see a difference. To answer your original questions, the rope should be where it always should be....near your hip, or as close as you can manage.
