Old    stevenf            06-20-2004, 4:58 PM Reply
ok mine is 62 inches long but how do you measure the diameter? i used a piece of string and came up with 42 1/2 i dont think that can be right? does anyone know the exact?
Old    Shawn Jessup (bigjessup)      Join Date: May 2002       06-20-2004, 5:23 PM Reply
Did you measure all the way around the bag? Cause that would give you circumference. To find diameter measure across one of the ends. I believe its 15" or so.
Old    Darren Yearsley (ralph)      Join Date: Apr 2002       06-20-2004, 5:42 PM Reply
Can you get a bigger bag than stock in there?
Old    stevenf            06-20-2004, 6:44 PM Reply
ok that makes sense measure across instead of around. ill do that. I thought that was way to big. as far as getting a bigger bag in there..i believe not. Inflated its stuffed in there pretty tight....I found a site bigwake.com that makes custom bags. If you get 4 fittings 3 like stock, and one in the middle of the bag on the top, you will be able to bleed the air out for more water...
