Old     (billyboard)      Join Date: Apr 2004       06-14-2004, 5:42 PM Reply
I just discovered a 3/8" inch "rip" in the center ballast bladder of my 2001 X-Star.
Can this be repaired (like a water-bed repair kit?) or does the pressure of filling a bag full all the time make it a candidate for replacement?
I don't want to be penny wise and dollar foolish, but I also know a penny saved is a penny earned.
Who makes the replacement bladders? Its a blue bladder about 65 inches long (the end is about 12 inches in diameter though I guess the middle expands further than that) with 3 openings at one end for hose fittings.
It sits inside a protective cover that has a 66 inch long pvc pipe on the outside that fits along the length to hold its shape.
Thanks
Old     (rrbooker)      Join Date: Feb 2003       06-14-2004, 6:54 PM Reply
I've replaced my center ballast 5 times over 3 years. I took it back to the dealer i bought it from. They had a recall on them, at least for the 2000s. I'm not sure about the 01s. I guess it depends on where the rip is. All of the ones i had, ripped right at the drain house on the bottom. I guess if you cut the bag yourself you can't have them replace it for free. I have used a water bed repair kit on one of my bladders in the front, works fine.
Old     (billyboard)      Join Date: Apr 2004       06-20-2004, 6:48 AM Reply
I used a water bed repair kit. As was suggested by the bed place, I put a small circular patch on first, and then after that dried overnight, I put a slightly larger circular patch over that one.
As long as the tear is not on a seam, I was told the patch should hold.
