Go Back   WakeWorld > Other Water Sports > Hydrofoiling
Old    goochy (goochy)      Join Date: Feb 2002       05-17-2004, 6:48 PM Reply
My new 2004 Billet Sky Ski , with chrome shock tower
Old    goochy (goochy)      Join Date: Feb 2002       05-17-2004, 6:49 PM Reply
A lazyboy
Old    goochy (goochy)      Join Date: Feb 2002       05-17-2004, 6:54 PM Reply
The foils are different, t bar taller, its billet not cast. This is one sweet ski !!
Old    airfreak (airfreak)      Join Date: Jul 2001       05-18-2004, 8:21 PM Reply
What's the length on the strut? I have heard it's the same as the cast and some says it longer. I would really like an LE but it is sounding like the new pro might be the upgrade it get. How's the skidders?
Old    goochy (goochy)      Join Date: Feb 2002       06-03-2004, 9:13 PM Reply
Not sure on the lenght, but its alittle longer. skidders are ok, but still hard for me. I still love it !!!!!!!
Old    goochy (goochy)      Join Date: Feb 2002       06-03-2004, 9:14 PM Reply
Failed backflip !!!!!! It hurt !!
Old    Sean M (magic)      Join Date: Mar 2002       06-04-2004, 9:25 AM Reply
Goochy, are you over or under rotating your gainers? Are you getting off axis at all?
It's hard to tell from the pic above, but from you wake jumps you have the jump to pull off gainers.
Do a progressive cut out all most parallel to the boat (start your cut slow, stay up don't ride the ski on the water, cut harder as you get further out, square back to the boat, drift for a moment to start slacking the rope, jump, then look back for the landing.
If you are over rotating the flip, watch you free hand. Often people throw their other hand up, this speeds up the rotation. Try putting it on your knee.
Under rotating is easier, just jump and look back for the landing more (break at the waist a bit, lay it out somewhat).
Getting pulled to side means that you don't have slack in the rope. Cut harder or don't drift as long.
Hope that helps!!!
Old                06-04-2004, 11:54 PM Reply
Can someone give me some tips on how to get the foil that high out of the water.
Old    Sean M (magic)      Join Date: Mar 2002       06-05-2004, 1:24 PM Reply
Larry, the good folks at foilfreaks.com have a great set of downloadible how-to's.
Here is a link to bigger air in the flats
http://www.foilfreaks.com/Tutorials/FlatsTakeOff/FlatsTakeOff1.htm
Once you are comfortible with those, you can take them higher by using the wake. Riding the foil up the crest of the wake will get you more air. That requires some timing and you'll find that different boats have really different shaped wakes requiring changes in your jump.
