Old    Ryan Reeves (afwakepilot13)      Join Date: Feb 2004       04-26-2004, 3:36 PM Reply
I recently switched from a Motive 134 to a Premier 141 and love it. The only thing is when I do wake jumps, spins, or grabs, the board is alot more vertical in the air than it used to be. I'm getting alot more air than I used to, and I'm landing everything even better than before, but it just makes my grabs/spins not look as good. Any advice on why this is happening, and what I could do to fix it?
Old    Sean (canaday)      Join Date: Dec 2002       04-26-2004, 6:19 PM Reply
Put more weight on your front foot if it's rising up in your jumps
Old    Christopher Stack (deepstructure)      Join Date: Jun 2002       04-26-2004, 6:24 PM Reply
you went from a continuous rocker to a subtle 3-stager. that'll pop you up a bit more. continuous boards will cut thru the top of the wake more, 3-stages will pop up more. so it makes sense that you're getting some nose rise. it'll just take some time for you to adjust to it that's all.
like sean said, test adding a bit more weight to the front as you're leaving the wake - perhaps a more even distribution is a better way to describe it. you'll get used to the new board soon enough im sure.
