Old    nash jeffries (nashjeffries)      Join Date: Feb 2004       04-13-2004, 9:06 AM Reply
go into the wake with a little lean back and look to you back shoulder with the rope close in?
Old    BoRed (sdboardr99)      Join Date: Aug 2001       04-13-2004, 11:54 AM Reply
http://www.wakeworld.com/Tricklist/TrickTip004.asp
Old    Harry (harryhog)      Join Date: Mar 2003       04-18-2004, 6:40 AM Reply
i've only just started backrolls, and before i was trying to initiate the spin before the pop. this resulted in loosing loads of pop and doing a poor roll.
i've found that now i approach the wake as normal, and at the moment of popping, i throw my hips forward and shoulder back. this would be the same if you were doing it off a trampoline, u'd initiate the roll as you jump, not before. This then allows you to use the same pop as before, and then give yourself more air time to spin.
Old                04-20-2004, 7:08 PM Reply
all you need is to go 15' wide with a nice PROGRESSIVE cut, try to tuch your rear ears on your rear shoulder and don't forget to pop. there ya go
