Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 01, 2004
Old    Lance (uga33)      Join Date: Jul 2003       03-29-2004, 2:06 PM Reply
What are yall using for your battery terminals. I have 4 guage cables going to my amp and the terminal I'm trying use will not stay on. I have the Stinger terminals that supposely just crimp on. Are you supposed to solder them on or something?
Old    Derek Bosia (dbo)      Join Date: Feb 2004       03-29-2004, 2:18 PM Reply
try the ring terminals by stinger that just tighten up with an allen wrench they work well.
Old    Jeff Reese (jeffr)      Join Date: May 2002       03-29-2004, 2:53 PM Reply
I have some crimp on ones.... nothing fancy…. I can slip the end over the accessory post and use the wing nut to hold the wires for my amps and pumps in place.
I have also seen some cool stuff in the back of the crutchfield catalogue with the allen key type of end. Check your local car stereo shops like car toys or mag hi fi for options.
You can find some great connectors. Depending on how many amps you are running they also have some splitters with fuses that would cut down on how many power and ground lines you would need to run.
Old    Lance (uga33)      Join Date: Jul 2003       03-30-2004, 6:07 AM Reply
Thanks Guys,
Old    Trace (trace)      Join Date: Feb 2002       03-30-2004, 6:13 AM Reply
use wire cutters to crimp instead of pliers, just be careful not to cut all the way thru the teminal. you can also "tin" the stripped wire with solder before crimping.
Old    whitevlx            03-30-2004, 9:15 AM Reply
Streetwires makes some nice connectors that use a screw to clamp on.
