Old     (codykauz)      Join Date: Jul 2007       07-20-2007, 8:54 AM Reply
i have an '06 mobius xlv with the 1950 lbs of factory ballast. i am looking to at least step up to larger sacks in the back but i don't know if i should ditch the stock sacks and just buy larger ones or t off the stock setup and add a second sack to each compartment. also i was wondering if the is any way to add weight to the mid section with other than people.thanks
Old     (o2binvallarta)      Join Date: Jul 2006       07-20-2007, 8:58 AM Reply
Lead bricks or those lead shot bags (name escapes me right now).
Old     (entrustclothing)      Join Date: Jul 2005       07-20-2007, 9:01 AM Reply
i have an xlv as well and i have 2600lb of ballast, i have the 1100lb front bag and i swapped out the rears for the fly high 750lb bags, i love the wake!
Old     (wake1823)      Join Date: Dec 2005       07-20-2007, 9:19 AM Reply
the stock ballast on the 06 xlv is not 1950lb, closer to probably 1200-1400lbs
Old     (entrustclothing)      Join Date: Jul 2005       07-20-2007, 9:32 AM Reply
stock ballast is 1150lb but the stock upgraded is 1950lb
Old     (acurtis_ttu)      Join Date: May 2004       07-20-2007, 9:41 AM Reply
cody, hwo big are your rear bags? I haev a pair of lightly used fly high 750's I may be willing to trade for your pair. I have an 07 SSV and want bigger bags in the rear. What are the dimensions of your current rear bags? How much weight are they?
Old     (codykauz)      Join Date: Jul 2007       07-20-2007, 9:57 AM Reply
entrust: thats what i am considering doing i've heard good things about going up to 700-750lb rear bags. are those easy to find it seams like the ones i've seen are too long.
adam the stock rear bags are 400lb each and are approx. 12" tall x 18" wide and about 4' or so long.
Old     (codykauz)      Join Date: Jul 2007       07-20-2007, 9:58 AM Reply
entrust: i was also just wondering (assuming you have this option) where do you usually set your wake plate and do you keep it trimmed down more now with the larger bags in the rear
Old     (entrustclothing)      Join Date: Jul 2005       07-20-2007, 10:09 AM Reply
the 750lb bags are easy to find and like $150 each i think.
if im full weighted i run the plate about 1/2 way, that seems to be where it works best for me.
Old     (acurtis_ttu)      Join Date: May 2004       07-20-2007, 10:25 AM Reply
cody, I ahev 400lb bags itn eh rear too, I thought you may have had the gravity games bags that are 550#'s. you cna get the dimensions for the 750's @ fatsac.com. they are too big for my lockers.
Old     (codykauz)      Join Date: Jul 2007       07-20-2007, 10:42 AM Reply
adam: thanks for the info, i'll check them out hopefully they will work for me.
entrust: at the beginning of the season i started running the plate around 1/3 to 1/2 up but recently i have been having to trim down completely to keep the wake from either shooting a tube or washing, thats why i was asking this seems strange to me and i am also sort of worried about adding more weight to the stern if i already have to stay trimmed down.
Old     (entrustclothing)      Join Date: Jul 2005       07-20-2007, 10:48 AM Reply
hmm im not sure, i like a really steep wake so i tend to run it more up, also sometimes i don't fill the back bags all the way, so there is maybe 600lbs in them a lot
Old     (codykauz)      Join Date: Jul 2007       07-20-2007, 10:51 AM Reply
yeah i also prefer a steep wake but i also try to keep a clean lip. how many people usually ride with you? do you keep them up front or in the back?
Old     (entrustclothing)      Join Date: Jul 2005       07-20-2007, 12:11 PM Reply
i have anywhere from 3-8 usually, i usually try to balance people out around the boat
Old     (codykauz)      Join Date: Jul 2007       07-20-2007, 12:28 PM Reply
thanks for all of the help, maybe tonight it will be calm enough for me to really be able to try some different adjustments. usually i just get everybody taken car of from side to side to make sure i get an even wake maybe tonight i'll try to get everything situated throughout the boat and start trying to really perfect the setup.
Old     (bird_dog0347)      Join Date: Feb 2006       07-20-2007, 12:38 PM Reply
Cody, check to make sure your front bag is not getting full of air. We had that problem on our 07 LSV but now we just check it every few times to make sure it is ok and full of water, not air.
Old     (tmobe)      Join Date: Mar 2007       07-20-2007, 12:59 PM Reply
I have been waiting for this kind of thread. So check this out. My 07 XLV GG bow bag does fill up with air while towing. Once I drop in I turn on the pump and burp it. I know that one is 1150lbs. As far as the back I have been trying to find out how many pounds they are. I did read that the back stock are 400lbs each but they are huge. They cant be only 400lbs. 12" tall x 18" wide and about 6' long. Sean, are they 750lbs each? As far as weighting it beyond that I put a 750 in the playpen and 2 600's on the floor with 5 peeps and little to no plate. With more people I dump some weight. Curls too much. With just the stock ballast full and 5 peeps I find the plate at 1/4 is perfect. And with no ballast, no bags and 5 people the wake is incredible at 1/2 to 3/4 plate. I love this boat. Anyone know the best way to weight it for surf?
Old     (zacharoo)      Join Date: Nov 2005       07-20-2007, 1:25 PM Reply
I have a 05 xlv and just got a 1100lbs front bag. We love it full and 600lbs in my two rear 750's. I have a hard time surfing my wake, but I weight 200 pounds. My buddies are smaller and have no problem. I have even tried putting both bags in one rear locker 1500 pounds. I need to try that with the bigger front bag.
Yall post pics of your XLV'sUpload
Old     (tmobe)      Join Date: Mar 2007       07-20-2007, 1:33 PM Reply
I like your 05 graphic better then the 07 on mine. I had the same graphic on my 05 LSV. So far I fill the bow ballast, then the back ballast that I want to surf on, then strap a 500lbs bag on the same side on the seat and play with the plate. Pretty big and clean but always room for advice.
Old     (tmobe)      Join Date: Mar 2007       07-20-2007, 1:39 PM Reply
Old     (zo1)      Join Date: Aug 2002       07-20-2007, 2:10 PM Reply
I wanna play two...
We have the 650 bag in the fron and two 750's in the back and a 150 that we move around in the cabin to balance it all out.
Boarding they are all filled, wakeplate about 1/2.
Surfing I fill the 750 on the side that we are surfing and the front bag full. Decent wake but I need the time moer than anything to play with it and get it dialed...
Old     (tmobe)      Join Date: Mar 2007       07-20-2007, 2:23 PM Reply
That boat house is AWESOME! I wanna visit!
Old     (madison_boarder)      Join Date: Apr 2006       07-20-2007, 2:40 PM Reply
ditto! Are there any good pharmacutical jobs in NC? My Fiancee will have her PhD soon and I'd love to live near you and mooch ;-) J/K Sweet set up! You've done well for yourself.
Old     (entrustclothing)      Join Date: Jul 2005       07-20-2007, 2:42 PM Reply
Old     (codykauz)      Join Date: Jul 2007       07-22-2007, 4:34 PM Reply
nick, yea my front bag was full of air. when we out the last couple times we have been running all bags full and wake plate just over 1/2 way to 3/4 trimmed up and it has been real meaty.
and todd i'm pretty sure the gg edition comes with 1180lb sac up front and two 550's in the back instead of the 400's but moomba doesn't tell you that because that would put you over your uscg approved weight rating.
ballast and weighting is no longer a problem for me, now my boat likes to dance, it does a nice shimmy shake. thanks to missing a blade on my prop. thats right a 3 blade doesn't run as smooth as a 4 blade.
the strange thing is i don't think we hit anything and the other blades seem to be in pretty good shape and one is just missing at the hub. sweet huh, guess i'm out to look for a new and hopefully better one, any suggestions? other than a 13.7x17.5 oj
Old     (entrustclothing)      Join Date: Jul 2005       07-22-2007, 7:35 PM Reply
the 13.5x17.5 is the worst prop ever for a weighted boat
i run the 14.25x14.5 its money! with 4000lb it still gets up and goes!
Old     (rbc_racing)      Join Date: Jan 2007       07-22-2007, 8:56 PM Reply
I just upgraded to the 14.25x14.5 prop on mine and I was amazed at the difference, delta propellers had the best deal I could find on the prop. With full factory ballast a 500 lb sack in the front walkway, 4 ppl and about 1/2 wakeplate and the wake was great and it still got on plane quickly.
Old     (codykauz)      Join Date: Jul 2007       07-23-2007, 4:31 AM Reply
nice thanks guys i have to talk to the dealer today about warranty stuff so i'm going to try to talk him into reimbursing me on one instead of replacing mine.
Old     (tmobe)      Join Date: Mar 2007       07-23-2007, 11:21 AM Reply
Definitely the 14.25 X 14.50 OJ! I had the stock one on and it was a pig with weight. Changed it for the second outing and BEST EVER! Many of my friends are now getting the same prop.
Cody, yeah...still don't know for sure what those back bags are. I think Entrust(sean)said 750, you said 550, and the site says 400. lol
Old     (codykauz)      Join Date: Jul 2007       07-23-2007, 11:49 AM Reply
todd, entrust might be right they might be the 750's i'm not sure hopefully they are the 750's i guess.
Old     (codykauz)      Join Date: Jul 2007       07-23-2007, 11:54 AM Reply
and to everyone else, for surfing adding weight to one side on the xlv doesn't seem to help the cause. make sure to keep some weight up front or trim down a bit to make sure that you are keeping the wake open wide enough for surfing. if you angled right at the boat and still dipping your front heelside edge try trimming down some.
Old     (tmobe)      Join Date: Mar 2007       07-23-2007, 11:56 AM Reply
haha. It's cool. I'm happy with what ever they are.
Old     (zo1)      Join Date: Aug 2002       07-23-2007, 12:12 PM Reply
if you guys are wondering what the stock bags are I am not sure of the exact weight but they are not the 750's...
Thanks for the nice comment on the BH. ABout my favorite place on earth right now...
Old     (codykauz)      Join Date: Jul 2007       07-23-2007, 4:03 PM Reply
oh yea
