07-08-2006, 3:54 PM
I just purchased 1 JL 10W7 and a JL 500/1 amp. It is going to be installed under the seat of the SAN 210 in a custom enclosure. Has anyone else run this sub in a boat? I have heard good things about it but have never listened to it. I know it is kind of a sin not to listen to speakers before buying them, but I didn't have time. Any feedback would be great.
07-08-2006, 3:58 PM
Great sub but I think 500w for a W7 is not enough,10" W6 wants that much not sure about the W7.I got 2-10" W6 and got the 1000/1 and I think it's just enough to push them.
07-08-2006, 4:10 PM
Thanks ed, I wish I had the cash to buy two of these things. Just the subs run about $550 a piece. It was really an impulse buy. I just got tired of listening to the stock Polk 10" sub.
07-08-2006, 5:11 PM
The W7 is the best sub for a vehicle, but I would choose a W6 for a boat. A 500/1 is great for a W6, but is a little bit of an underachiever for the W7. Consider swapping your 10W7 for a 12W6?
07-08-2006, 5:36 PM
Rob, I have already purchased the sub and amp and they are working on a box as we speak. I could return the amp for a more powerful one, but the sub is locked in. Why would this sub not work well in a boat? I don't know that much about audio but I would think if it worked well in a car, it would do well in a boat.
07-08-2006, 5:58 PM
Quote.. "The W7 is the best sub for a vehicle, but I would choose a W6 for a boat. A 500/1 is great for a W6, but is a little bit of an underachiever for the W7. Consider swapping your 10W7 for a 12W6?" Huh? Why would you say the W6 is better in a boat than the W7? Just curious.
07-08-2006, 6:20 PM
I have a 12W7 and 500/1 in an enzo under the drivers side dash and it sounds way good. If some say it is underpowered they may be right but mine hits harder and goes louder than I can stand. You wont be disapointed just my thoughts.
07-08-2006, 6:38 PM
W7's run hot and are competition subs. The W6 can put up with more of the weather elements and abuse exposed in a boat.
07-08-2006, 10:11 PM
Thanks BKS, That makes sense rob...thanks Mike
07-09-2006, 7:07 AM
I'm running a 10 W7 with the JL 500/1. Works great, I am using a JL box also. If you build a box make sure you do it right or you will blow it apart. I am also runing two more JL amps for the inside and tower. Wet Sounds are the way to go now for the tower. They are be driven be a 300/2 Just my opinion. Keep the amp and sub just build a good box.
07-09-2006, 9:27 AM
Thanks Jim
07-09-2006, 11:44 AM
Mike, do you drive a Camero? (Just trying to find out what ponyh8r means)
07-09-2006, 6:02 PM
I used to when I was younger. Now it is just something easy to use because I don't really like to try to remember different logins for several boards. Good job by the way. Mike
07-10-2006, 8:40 AM
For those who have a w7 underneath the drivers seat how does it sound. I have never heard a w7 and was curious if all the hype is true.
07-10-2006, 9:15 AM
never heard one on a 500/1, but on a 1000/1, in the right box, it will shake your eyeballs
07-10-2006, 10:56 AM
JL amps are the RMS, not the max. All jl amps are 2x what they say they are. Same with subs. They under rate everything. Trust me, a 1000/1 will blow a 10w7 with ease. The 10w7 has a 500 watt rms. A jl 500/1 has 500 watts rms. They both have 1000 watt max so they are perfect with each other. I have 2 13w7 and 2 1000/1 in my truck and its loud as hell. Its a perfect setup because the 13w7 has rms of 1000 watts and peak of 2000 watts which is what the amp has also so i dont blow my subs and i dont fry my amp.
07-10-2006, 3:33 PM
I forgot. Is it worth all the extra money compared to a w6?
07-10-2006, 3:47 PM
There is no comparison between a W6 and a W7 if you really want to know.
07-10-2006, 3:56 PM
Josh-I have a 1000/1 that I originally planned to run 2 ported 12w6's in two sep boxs (1 under driver and other in passenger compartment) I have the one under the driver but still have yet to hook up the other sub in fear. The single when turned up rattles my new boat so hard I worry what two would do. I've heard the W7's and they are spectacular, I just dont know if its worth it in boat. Maybe I should have gone sealed instead of ported.
07-10-2006, 5:49 PM
I have a 13w7 powered by a 1000/1 and it thumps. I also have 2 300/2's...one for each NVS addiction. I also have a 450/4 powering my cce770's. Sounds pretty great.
Thread Tools |
Display Modes |
Linear Mode
