Production models are scheduled to be available in 2010, updates and details can be found at
http://23e.epicboats.com/ Below is some basic info.
Over 50% reduced total carbon dioxide emissions.
Virtually no risk of CO poisoning with our hybrid drive system.
The Epic 23e burns 50% less fuel than a typical wakeboard boat on a 4 hour wakeboard outing.
You can wakeboard for 1 hour on batteries without ever burning a drop of fuel.
It can be fully re-charged by the generator in about an hour.
The 23e can be re-charged from a typical 110v wall outlet or a 220v wall outlet once home or at the dock.
Boat Specs
HULL
Hull Length........................22’9”
Beam...................................98”
Seating......................14 people
Approximate Weight.....5000lbs
BATTERY PACK
Type...Flux Propulsion LiFEPOWER
Energy (kWh)...............................60
MOTOR
Brushless DC Water cooled
Max Net Power.....268 HP (200kW)
Max rpm..................................4000
Torque................442 ft/lb (600 Nm)
CHARGING
Generator
Engine....................TDI 165
Power Output.............45kW
Fuel.........Diesel/Bio-Diesel
Plug-in Charger
Voltage Input.......Universal
Output......................3.3kW
