Old     (mainelaker)      Join Date: Feb 2003       08-24-2003, 3:07 PM Reply
I have a new Centurion Hurricane & I installed perfect pass this weekend. It hunts about 1.5 miles an hour with a rider. I think the problem is b/c the throttle cable increases in angle from the bracket to the throttle body then the PP installs on the cable & will drop down due to the location of the servo on the exhaust hose. I think if I could create a bracket to keep the PP cable at the right height it wouldn't hunt as much. It states in the install manual to not have any gap between the PP cable & throttle cable but how can you do that when it doesn't have a rigid connection to the cable? Quite frankly I think the servo part of the system is a little cheesy & they should have thought the design out a little better. I'm sure the slight gap is the cause of my problems but how do I solve it?
Old     (trace)      Join Date: Feb 2002       08-24-2003, 5:34 PM Reply
i have a Vdrive, but i had a similar problem. my cable had a tight bend in it when it was mounted to the cooling hose. i made a bracket for mine & mounted it under the deck in the starboard rear storage. this also isolated it from heat of the exhaust risers. here's a pic with the compartment divider down:
engine
the servo should remove all the slack from the cable when the PP unit is powered up. there shouldn't be a "gap", but i don't think it's a big deal if there's a bend in the cable between the fittings, as long as the fittings are all pulled together when you're idling in neutral.
Old     (krbaugh)      Join Date: Mar 2002       08-24-2003, 8:08 PM Reply
Does it do this is MPH mode and RPM mode?
If it holds speed good in RPM mode and fluctuates in MPH mode it can be 2 things paddle wheel or the computer module.
Call Perfect pass they are a HUGE help
Old     (mainelaker)      Join Date: Feb 2003       08-25-2003, 2:26 AM Reply
I haven't tried RPM mode yet & won't be near my boat until next weekend.
Old     (uga33)      Join Date: Jul 2003       08-25-2003, 5:17 AM Reply
I have a 2002 Hurricane and Installed perfect pass as well. Mine holds real good in calm waters .5 MPH+/-. However, in rough water it is about 1 to 1.5 MPH+/-.
Old    barryb            08-25-2003, 6:12 PM Reply
The tightness of the bend makes a huge difference.
Set the boat at half throttle (motor off). Then open the motorbox, grab the PP control wheel, and rotate it around. Watch the throttle lever on the engine when you do this. If it moves both in and out perfectly smoothly with your rotation of the wheel, you're in good shape.
If it's at all jerky when you let cable out you have to increase the radius of the bend or it won't work properly.
If it operates smoothly, your problem could be the gain (I believe PP calls it Kx) setting on the cruise control. Higher numbers make the PP unit
respond to changing speeds more quickly.
