after you drain your block, heater ,shower , remove your jtube from your thermostat housing and pour the antifreeze in it with a funnel....there is no need to remove the housing or the t stat......... as far as the walters vdrive remove the intake and exit hose and blow or suck out the water , no need to remove the drain plugs nothing will come out after you do the previous
