To your original question… I have ridden the 03 TFD in both the 142 and 136. I weigh 185-190. You could go either way at 175. Depends on how you ride… spins… inverts…. Switch…. Boat speed…. Etc.
At 22-24mph I did not feel either board felt faster than the other… granted the TFD is fast regardless. I did notice the larger board felt faster if I drop the boat speed down to around 20. So I guess it depends on what speed you ride at.
Add to the mix that with a larger board you can ride with a wider stance when you set your bindings all the way out. That was more noticeable to me in the feel of the board that the speed…. Especially when landing in the flats. Bigger size lands softer. I will also second the point that larger boards carry more speed on landings.
Not sure if I can put it into words to describe it… but there is a different feel as to how the 142 vs. 136 comes of the wake too…. You have to ride them back to back to see for yourself.
If your issue is regarding one board… just demo both sizes and see what rides best for you. The problem with generalizing big board vs. smaller board is that every board shape is different. My 141 Premier is way slower than my 136 TFD… and the old 144 Belmont lands way harder than my 136 TFD.
Re: snowboards…. It’s not jus the board size but also side cut radius, flex pattern, and effective edge. It’s not winter yet…. No more talking about snowboards.
