Old     (waketowake)      Join Date: Jul 2007       04-19-2010, 5:40 PM Reply
So I am 6 foot and about 150, i like the look of this board. I am just learning my 3s and tantrums. Is this a good board? Also i like the 2010 vapors, I'm thinking of doing a package. Has any body ridden the board or bindings? thoughts?
Old     (jondextan)      Join Date: Mar 2010       04-19-2010, 6:11 PM Reply
i found the Pure slow and rides deeper, compared to the boards i'm using now (which have flat featureless bottoms). Though i've heard a lot of good things about it. also, maybe you should consider going with something bigger than a 134 imo.
Old     (TimboSlice)      Join Date: Mar 2010       04-19-2010, 6:15 PM Reply
im 5-8 170 lbs and i rode the 141 last year...its super smooth, pops really well, and tracks fairly lose without the center fins which i prefer. you should consider the 141 though since itll pop harder and land softer than the 134
Old     (baitkiller)      Join Date: Jan 2010       04-19-2010, 6:19 PM Reply
I use the 141 with vapors for a boat board. People like it, smooth and steady, really predictable...
And it keeps them from using my Transcend.....
Old     (waketowake)      Join Date: Jul 2007       04-19-2010, 6:33 PM Reply
I have a trancend 138 now and it seems heavy, is there any ronix boards you guys would recommend?
Old     (baitkiller)      Join Date: Jan 2010       04-19-2010, 6:58 PM Reply
I just bought my son the 2010 Ronix Vision. Weighs nothing, awsome board. My next board will likely be a Ronix. But as for right now the Transcend is working just fine. I don't know enough about their (Ronix) line to recommend a particular board but what I have seen I quite like. I do own both the the 138 Tranny and the 141 Pure 2010 / 2009 and the Tranny is the board I prefer between the two.
I'm sure forum help is on the way. sit tight.
Old     (cwb4me)      Join Date: Apr 2010       04-19-2010, 7:02 PM Reply
i've ridden a transcend 142 and a 134 marius and a 140 marius. i'm 5'6" and weigh 175 lbs .the marius is faster more pop and soft landings in the flats.the 134 will work for you and it has less swing weight for spins.the 140 will ride smoother and pop higher. also give you about 1" wider stance.hope this will help.
Old     (jasonpav)      Join Date: Dec 2008       04-19-2010, 7:54 PM Reply
I would definitely suggest going for the 141. It will ride easier, pop higher, and land softer than the 134. plus... I honestly don't think a slightly bigger board hurts your spin much at all
Old     (waketowake)      Join Date: Jul 2007       04-19-2010, 8:16 PM Reply
I really like the ronix one 138 and the one bindings, any experince with those?
