Old     (tl7)      Join Date: Feb 2005       06-19-2011, 1:20 PM Reply
Has anyone done it? I need to replace mine (2010 Moomba LSV). It's broken, I'm assuming it happened when the trailer mfg was adjusting the bunks (just bought new aluminum trailer). However it happened, it happened, and now I need to replace it. Is this an easy fix? Anyone know a PN? I need both the paddlewheel and the housing....the actual housing has a bent "fin". Not sure what to call it. It's one of the walls that the actual wheel goes between. It's hard to tell in the pic that one of the walls is bent, but I bent it back to get the wheel out. It's plastic so the next time I move it at all it's going to crack.
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       06-19-2011, 1:30 PM Reply
This is the paddlewheel Perfect Pass uses and is the most common on most ski/wake boats. Not too pricey. They do sell a kit with a new paddlewheel that can be used if your housing is alright. They do sell a kit with just the metal pin/axle and the wheel if your housing is intact. Didn't see that on a quick search but I'm sure you could get one.
This looks like just the transducer part and, not including housing and whatnot... If that's the case it should be a drop in to replace what's damaged on yours.
http://www.p2marine.com/catalog/prod...ducts_id=18097
