04-29-2003, 6:16 PM
The lake I put my boat in leaves a stain on my white boat, I assume it's from the color of the water. The only product I've found that will remove the stain is CLR but am concerned about it's effect to the gelcoat. Anyone have experience with using CLR or know of another product to remove stains from the gel coat?
04-29-2003, 6:18 PM
try sno-bol. it is super cheap and works like a champ
04-29-2003, 6:28 PM
Star-Brite hull cleaner. Follow the directions exactly, and put a couple of coats of wax on your boat afterwards, you'll be happy. Also, a couple of coats of good wax will do wonders for being able to wipe stains off at the end of the day. -Jeff
04-29-2003, 6:34 PM
hull cleaner = $10 sno-bol = $1.30 use it on your boat, use it in the toilet. multi purpose.
04-29-2003, 6:43 PM
You need to get some FSR /fiberglass stain remover. This stuff is great!! Works so good...you guys should not be without it!
04-29-2003, 6:44 PM
Thanks for the advise so far, I have been putting on a couple of coats of wax in the spring and summer but still have the staining problem. Kind of concerned, due to planning to put the boat in the water for about six week straight. The lake I hit is way down and the ramp is a mess so am putting it in a slip. Any great products out there that will help prevent the stains?
04-29-2003, 6:47 PM
Any suggested on-line suppliers of FSR?
04-29-2003, 6:52 PM
04-29-2003, 7:05 PM
Thanks for the information!
04-29-2003, 11:45 PM
Would that stuff remove oxidization? I just bought a boat that looks like it's been neglected for a few years, the red is now a foggy pink. Whats the best wat to get rid of oxidization?
04-30-2003, 4:37 AM
SRF, Sno-bol is the best ive found
04-30-2003, 5:49 AM
The stain you have is caused by tannic acid. Here in Florida it is mostly comes from Cypress trees around the lake. FSR is the gentlest cleaner to use because its thick and will stick to the hull. It can do its job with out dripping all over the trailer. (but you have to paint it on thus, its more work. If you can find it, A to Z wheel cleaner in the black bottle (not the newer clear bottle) is a little easier on the trailer than sno-bol. If you do use sno-bol make sure you dilute it 50/50 at least! Sno-bol contains the most hydrocloric acid of all the products mentioned and will discolor your brass and may damage the trailer paint/powdercoat. If you have a galvanised trailer, drap some visqueen over as much of the trailer as possible. You will see instant changes in the galvanization as soon as the hydrocloric acid touches it. I have also found that I only get stained if I leave the boat in the water for days. If I take the boat out after one day of use, rain water and sunlight will take care of the mild stain.
04-30-2003, 10:44 AM
I checked into that FSR link, it's $7.95 a bottle plus like $8.75 shipping, I think I'll head down to my local marina instead.
04-30-2003, 11:19 AM
I had the same prolbem in the delta. I went to west marine and they told me about a product called on and off. Used it once and it worked like a charm. This was the first product that seem to work. You just spray it on and hose it off that easy no rubbing or scrubbing (its great)
04-30-2003, 11:45 AM
I agree with the sno-bol - it is suer easy to use and the hull looks brand new when your done. Just wipe it on with a sponge and hose it off two minutes later. Sandy has great advice about the trailer and the brass - keep the sno-bol away from it. Also - avoid the decals - it will eat them off.
04-30-2003, 2:16 PM
To get back to your original question, No I don't think CLR harms your gel coat. I have been using it for over three years on two new boats without any problems. I mix it 50/50 with water, spray on, wipe with rag, then rinse off.
04-30-2003, 4:56 PM
our boat was thick with scungey green/brown , we used acid wash-toilet bowl cleaner, and it worked like a charm, took about 10-15 minutyes to do the whole boat too.....spray it on, wash it off..
