matt, 4 inch or bigger fins on the blue will make it track like its on rails. mark and i have tried bigger fins on all the boards. if you like a tight feel that has lots of drive, big fins are the way to go. it will be a bit tougher to break it loose for spins and slides though. troy, you want the curve on the outside. if someone had the curve on the inside, they have the fins in the opposite fin box. the curve acts like a foil, an airplane wing for example. is physics ask mark.
