The perfect pass by design should only be capable of reducing speed, never increasing. Can't happen unless something is not installed correctly. More detail if needed... When you accelerate with the PP activated it reduces your throttle input, the servo feeds back against you. After it is engauged it will make adjustments up to the maximum throttle opening where your handle is. So if your throttle handle is halfway it cannot ever accelerate more than halfway, if it's at idle it cannot accelerate more than idle.
