Here is mine, 22 hours on her. I had a 03 gravity games LSV before this one and was very happy with it, 300 hours with no real problems. I love the 06, it has so much room and still handles like a smaller boat. Moomba up-grades in overall quality from the 03 are like night & day, upholstery, carpet, fit & finish is very nice. Huge rear storage and sun deck (wake boards fit in the trunk) The wake: We got the upgraded ballast with 2- 500 pounders in the back and 800 up front. As with my 03 i needed to add more weight up front, add a 400 in the walk through and it helps a lot. Wake has a longer transition but still pretty hard at the peak for good pop. We played with the weight for the last couple of weeks and here is what we ended up with. What I listed above, plus 150lbs in lead up front (75 each side under the seats) 150lbs in lead under the side seats in the middle (75 each side) If we have less then 4 peeps in the boat we use a 400 lbs sack in front of the rear seat. Most of the guys that ride with us are outlaw/pro level riders & this much weight might be to much for beginner to intermidate riders. Also if you add a lot of extra weight you will need to reset the Perfect Pass. If it ever quits raining
I will get some pic's of the wake and post them. You can't go wrong with this boat for the money. If you want addisional info send me a PM.
