Old     (dgunthert)      Join Date: Mar 2007       06-05-2007, 12:11 PM Reply
Why do manufacturers use the crappy waterbed type fittings that barely attach?
I know I've seen posts about adding a different fitting to a bag, but searching for things like "ballast fitting" returns about a ridiculous number of messages. Any advice on adding a fitting with a bit more beef to it?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-05-2007, 12:19 PM Reply
marine glue. take the other side off if you pull the bag out.
Old     (dgunthert)      Join Date: Mar 2007       06-05-2007, 12:22 PM Reply
Thanks for the response, but I don't really know what the heck that means. Marine glue what? Take the other side off of what if I pull the bag out of where?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-05-2007, 12:46 PM Reply
"Why do manufacturers use the crappy waterbed type fittings that barely attach?"
thats where I would use the glue!
"Take the other side off of what if I pull the bag out of where?"
uhh... the boat!
a fitting, for example, has two sides. It connects two "things." (i.e. a hose and a fat sac. ) I suggested you glue one "side" the other you could unscrew.
Thanks for the laugh!
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-05-2007, 12:54 PM Reply
some of the newer sacs have quick disconnect fittings and such. another option would be replacing all your sacs.
Old     (dgunthert)      Join Date: Mar 2007       06-05-2007, 1:03 PM Reply
Okay, you're talking about simply permanently gluing one of the crappy fittings like this:
http://www.wakeside.com/page/W/PROD/closeouts_discount_wakeboards/cwb_absolute_135_wakeboards_06
to the bag itself.
Since I'm looking at doing a permanent setup, I guess that would work. It obviously wouldn't work if I had to disconnect the hose to put the cap on.
Old     (bmartin)      Join Date: Jan 2007       06-05-2007, 1:32 PM Reply
If you are doing a more or less permanent set up, just forget about the fittings. The OD of 5/8" marine bilge hose fits perfectly inside the sac opening. Put the hose in the sac and put a hose clamp around the vinyl sac opening and your done. I also found that 3/4" garden hose fits nicely inside sac openings.
