Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 21, 2006
Old     (wake_upppp)      Join Date: Nov 2003       06-12-2006, 7:28 PM Reply
I made these up from lead shot that I found for $1 a pound to add to my 850 pound ballast system in my '06 Sanger V210. These way 25 pounds each. I will also be running a FlyHigh side sac in the walk thru, (250 pound), for a total of roughly 1400 pounds to start. It's not alot of weight but that is the beauty of narrower beamed hulls. I'll get some pics of the wake this coming weekend.
Old     (yosquire)      Join Date: Jun 2005       06-12-2006, 7:47 PM Reply
Those are filled with Lead Shot and they only weight 25 lbs a piece? I'd expect them to be 4 times that weight.
If I recall correctly, solid lead weights about 1.4lbs per Cubic Inch.
Old     (wake_upppp)      Join Date: Nov 2003       06-12-2006, 9:33 PM Reply
I watched them weigh it on the scale. 250 pounds of lead shot that I put into 10 containers = 25 pounds each. Consider that the shot is ball shaped. If you poured solid lead into the same container it would weigh more than the lead shot, but I doubt it would be four times more. Anyway, trust me it's lead shot and they're 25 pounds each, plus whatever the abs pipe and caps weigh.
Old     (showtime)      Join Date: Nov 2005       06-13-2006, 5:08 AM Reply
Actually pure lead is 0.41666 lbs per Cubic Inch.. or a cubic foot of lead is 720lbs--break that down 12"x12"x1/16" = 1 lb...
Old     (superairdawg)      Join Date: May 2003       06-13-2006, 5:29 AM Reply
Where did you score the lead shot? I went the ghetto route and had to settle for scrap lead from a shooting range. It's 'dirty' so won't be as dense per cubic inch as shot, but the price was right (FREE).
I put mine in bank coin bags so they conform to whereever I want them and have no pressure points. I'm in the process of getting some covers made to pretty them up a little.
Old     (shelstad)      Join Date: Oct 2005       06-13-2006, 8:32 AM Reply
Mark, I like your rocking horse! Where can I find one?
Thanks for all of the positive support!
I am looking into the pump-hookup issue right now..
P.S. I checked out your install pics...So Fresh and So Clean VERY NICE!
Old     (wake_upppp)      Join Date: Nov 2003       06-13-2006, 6:24 PM Reply
Chris, I found the fitting I need on Flow-Rite's site. It's listed in the marine section, 3/4 fittings. It's down at the bottom. They call it a 3/4 female pipe thread to quick-lock. My wife says the rocking horse is a few years old but if we see another one, it's got your name on it! Thanks so much again for all the help. Joe, I scored the lead shot at a local supply yard, there's more too but it would prolly be a fortune to ship. :-(
(Message edited by wake_upppp on June 13, 2006)
Old    walt            06-13-2006, 6:47 PM Reply
So where are you going to stash the lead Sparky ?
Old     (regalado1)      Join Date: Dec 2005       06-13-2006, 6:50 PM Reply
Looks too much like IED's to me.
Old     (wake_upppp)      Join Date: Nov 2003       06-13-2006, 7:18 PM Reply
Walt, under the bow cushions up front.
