Old     (rich_g)      Join Date: May 2003       04-03-2005, 5:31 PM Reply
Who makes the trailers for Centurion?
I have a 98 Elite-V (21')and have gone w/out a trailer since I've had it. I have a boat dock w/ lift, and access to a 23' Malibu trailer if I have to take it in. I have taken measurements off the bu, but it's not a perfect match. I bought a used 21' trailer that was for a MB Sport. The bunks are totally different and won't work for me.
I'm re-doing the bunk design, new uprights, bow stop, etc. It's fairly challenging - boats are so 3-dimensional ya know. If I could get a basic drawing from the mfg, I could hand it to my welder buddy, then I'd be home free. Any suggestions of who to call. Thanks
Old     (swab791)      Join Date: Mar 2005       04-03-2005, 7:04 PM Reply
Well since you are driving a TIGE 21I (EXACT SAME HULL MADE IN THE SAME PLANT) You might want to check out the local TIGE DEALER. Or the TIGE Plant in Texas.
Old     (ef3529)      Join Date: Nov 2003       04-03-2005, 8:19 PM Reply
If you are in Texas, Boatmate in Knoxville makes it.
Old    jmac_04            04-04-2005, 12:00 PM Reply
Magnum Trailers located in Austin Tx make a trailer for Centurion. That is what my Centurion is on. http://www.magnumtrailers.com
Old     (breadbutta)      Join Date: Dec 2003       04-05-2005, 7:19 PM Reply
Maybe these will help
(Message edited by breadbutta on April 05, 2005)
Old     (breadbutta)      Join Date: Dec 2003       04-05-2005, 7:21 PM Reply
Here's the tag
Old     (rich_g)      Join Date: May 2003       04-06-2005, 6:35 AM Reply
Bruce, thanks for the personal effort. That helps. I doubt that the mfg will give me their specs, but I can get pretty close by looking at different pictures. I'm not close enough to a dealer to make a visit very practical.
The skeg on my boat will be directly above the front axle. How much up & down motion do you get on the axles; normal leaf spring tandem setup? How much clearance should I build into it?
Old     (kstateskier)      Join Date: May 2002       04-06-2005, 11:34 AM Reply
Both our promo boats were on Boatmate trailers. Both were made at the NC plant though.
Old     (breadbutta)      Join Date: Dec 2003       04-06-2005, 4:31 PM Reply
Rich, Not much movement, from what I can remember. In the third picture you can see the cross member in the middle is a lot lower than the others, probably about 4 inches. Is it possible to move the boat forward or backward so the axle is between the skeg?
Bruce
