Old    brycejay            01-31-2010, 9:52 PM Reply
I know there is a difference in the base of a normal Liquid Force board and the Limiteds. Does the Limited base effect how the board rides at all? (faster, more slippery, etc?)
Old     (peter_sands)      Join Date: Jan 2010       02-01-2010, 2:21 AM Reply
There is no such thing, as Ldt. base. The Ldt. boards can have the grind base or normal base. The grind base on a Ldt. board and traditional board is the same. That also count' if it has the normal base. It's the same.
Old     (behindtheboat)      Join Date: Aug 2006       02-01-2010, 6:16 AM Reply
The Grind Base isn't noticeably different. May seem a little grippier on the water but definitely smoother gliding on rails.
IMO, it was not a noticeable difference on the water however.
Old    benj_t            02-01-2010, 10:45 AM Reply
Yeah I cant tell a different just on the water at all. but on the rails it is definetly way better because it slides smoother and faster whether the rail is wet or dry
Old     (andrew_moreton)      Join Date: Feb 2003       02-01-2010, 11:20 AM Reply
You won't really notice a difference on the water, but like Benj said, it's great on rails, even if the rails are dry.
Old    brycejay            02-01-2010, 11:46 AM Reply
Yeah, I live a long ways from any slider so I won't be using for that. Just wanted to make sure it wouldn't effect the ride behind the boat. Thanks guys
Old     (gunnertom4593)      Join Date: Sep 2008       02-01-2010, 12:15 PM Reply
Stiffer and a little heavier because of the extra thickness, and I noticed that it's a little looser too because the fins aren't as deep.
Old     (cheesydog)      Join Date: Mar 2009       02-01-2010, 6:22 PM Reply
yup ltds are a different ride to the regular versions. For example the S4 which has pretty sharp molded in fins are a lot mellower on the ltd, which makes it a looser board and not quite as grippy.
Old    brycejay            02-01-2010, 6:59 PM Reply
Well I like my boards on the looser side. Just ordered a Lyman 139 LTD board, so hopefully it will be just right.
Old    benj_t            02-02-2010, 8:41 AM Reply
Bryce thats awesome. i rode the LTD Lyman in 2009 it has been the best board ever. Good Luck youre going to love it.
Old    brycejay            02-02-2010, 9:30 AM Reply
Thanks benj! I've been a little nervous about getting it cuz I've ridden the shane for the last 3 years. I was looking for something different and ended up deciding on the Lyman. Can't wait to give it a go!
Old    benj_t            02-02-2010, 2:59 PM Reply
Yeah man I think youre going to like the Lyman even better than the shane
