OK guys, pulled the boat out to start it up in the driveway yesterday. I like to make sure everything is working OK so I don't have to discover a problem at the lake and possibly blow a whole day. Better to find the problem early and fix...
Anyway, started up the boat with the fake a lake, let the water run for a minute or two to prime the impeller. Boat started fine and ran fine, but upon feeling the exhaust manifolds, only one was hot. and the heater ran cold. Temp gauge indicated 165 or so for several minutes...
So, why would only one manifold be really hot to the touch, and the other one be as cold as the water coming in from the hose? I also noticed that the fake-a-lake had been picked up off the ground, presumably from strong suction from the water intake (yes, i had my hose on full blast).
Anything to worry about here? Everything was running fine, except the heater blew cold. Water coming out of the hot exhaust port side seemed warm, other exhaust port seemed cold. Is this normal? or should I be worried?
