Go Back   WakeWorld > Industry Jobs
Old     (rockwell)      Join Date: Jun 2008       06-09-2008, 2:34 PM Reply
Hey, we're looking for an intern to help in Search Engine Optimization and to help in other IT areas. hit us up at info@rockwelltime.com if you're interested
Also, check out who we are at www.rockwelltime.com
or add us at www.myspace.com/rockwell_watches
Thanks for the help!
Old     (alteczen)      Join Date: Aug 2003       06-25-2008, 5:40 AM Reply
I'm not interested in applying for the position but I can give you one BIG pointer that is a huge problem with your site - it's all done in Flash!
Bots (from google, yahoo, msn, etc) cannot read any of your content on your site. You need to convert your site to use flash for banners and graphics first and foremost.
Old     (mnwakerider)      Join Date: Jun 2004       07-09-2008, 6:08 AM Reply
Al too true. The major brands that do not care about SEO (because it happens naturally...) use flash, so this is most likely why you used flash. Flash is written in a code format that loads evertything initially and then keeps the "same" page up. THis same page changes to the user, but everything from a code/setup standpoint is the same; Therefor a google bot or other search engine spiders cannot "crawl" your page and get the necessary information.
There are ways to get some SEO on Flash sites, but it is comparitively way less effective.
Good luck in your search!
Old     (ryanandlea)      Join Date: May 2006       07-23-2008, 11:50 AM Reply
On a positive note, your watches are pretty SICK...The 50mm is sweet, a little pricy though. Just how big is that thing?!
Old     (jsweat)      Join Date: Apr 2007       07-23-2008, 12:00 PM Reply
my guess is the case is 50mm (hints the name) which is massive
Old     (rockwell)      Join Date: Jun 2008       07-23-2008, 1:08 PM Reply
yeah, its 50mm alright. It has a sibling coming out soon called the 50mm Squared. It is going to be so freaking sick!!! It'll be here in time for all your Christmas needs
Old     (proimages)      Join Date: Nov 2007       10-20-2008, 9:22 PM Reply
Watches look great! seems you got past the flash issues..still needs a lot more work on the SEO stuff! Also should never end in .php
contact me at proimages.com
if your still looking for upgrades
cheers
Darrin
