Old     (martyslc)      Join Date: Jul 2007       03-12-2008, 12:50 PM Reply
Has anyone added another set of brakes to their trailer? I have one set now but want to put some on the back axel. I have got the rotor kits, etc on their way from the manufacturer (UFP) but they said they can’t help with the brake line stuff. I have emailed “BoatMate” (Trailer Manufacturer) for help but haven’t heard back. All I need to do is bolt up the new set of brakes and then connect into the brake line some how. That’s where I don’t know what to do.
Do I need metal line just to go back 3 feet to the back brakes or can I just use the flexible rubber line and tee off the front ones?
Old     (olskooltige)      Join Date: Mar 2007       03-12-2008, 1:11 PM Reply
DOT approved flexible rubber line is fine. Add a tee at or around the other tee, or at the coupler on the frame if you have one. You should have one on the axle too. I would route it back out and up to the frame again, and then back down to the rear axle.
(Message edited by olSkoolTige on March 12, 2008)
Old     (chpthril)      Join Date: Oct 2007       03-13-2008, 5:46 AM Reply
Use a steel tee, not brass.
