12-31-2004, 5:37 PM
i need sum ideas on how to get used to riding switch??! i'm fine at goofy but cant get used to regular.. is it all muscle memory?
12-31-2004, 6:05 PM
practice, practice, & more practice
12-31-2004, 6:21 PM
what chuck said, i haven't been on the water in like 5 months, but I just started to ride switch near the end. The first time up was a nightmare, I could only go for about 50 yards, it just felt so damn akward. But just like anything, the more I did it, the more comfortable I got. Just cant get frustrated and keep working at it. Good luck.
12-31-2004, 6:43 PM
sweet thanks!... i figured.. i didnt know if i was like deformed or sumthing.. hahaha..
12-31-2004, 7:01 PM
Devote every other set to riding switch
01-01-2005, 6:36 PM
snowboard and skateboard
01-01-2005, 8:03 PM
I always start the first set by getting up switch. I ride goofy so regular was really strange. Getting up switch seemed to be easier in the beginning than a surface 180. riding switch first also means that you're not tired and less likely to develope a bad habit while learning something difficult/different. just seems to work for me
01-03-2005, 7:05 AM
break your other arm
01-03-2005, 7:20 AM
yeah what toolfan said, break your lead arm so you have to ride swtich all the time. its almost a good idea!
01-03-2005, 9:48 AM
Break your arm??? In that case just tie it up!! But really just practice and you'll see it's not that difficult.That's what I did snowboarding and now I can go down the mountain any which way with the best of them SWITCH!! Just need to do that in WB now!! YOU NEED WATER TIME!!
01-03-2005, 11:03 AM
If you don't have a skate board, buy an old one or borrow one. Ride it switch up and down your street when you are not on the water and it will start to feel natural. The more practice....the easier it gets
01-05-2005, 10:58 PM
Learn to chop switch on a skateboard.
01-06-2005, 7:31 AM
I got pretty good a switch by taking one switch session each time I ride. I just take one whole set and ride switch. The more I did it the better I got, now I can almost do everything switch that I can do regular. And some stuff I can only do switch.
01-06-2005, 8:45 AM
Yeah, if you think wakeboarding switch feels awkward, try skating switch. WAY tougher for me. "Now, which leg do I push with", and "as long as I don't have to turn". Wonder how it feels surfing?
01-06-2005, 9:52 AM
Ive found that the best way to learn riding switch is by doing it in rougher water. The whole time ur trying to keep your balance and work on edging back and forth, bunnyhops, etc. Once u get back in smooth water and ride switch itll be alot easier.
01-06-2005, 9:59 AM
I think that all you need to do is practice a few times every set. Cut out 1st on your heelside a few times then your toeside. I'm not to sure if this is the same with anyone else but I couldn't use a skateboard to help with my switch rideing bc on a wakeboard my natural stance is goofie but on a skate board it's regular so maybe I'm just weird or w/e but my sugguestion is to try a friends and see if your wake/skate board stances are the same before you spend your $ if you haven't already
01-06-2005, 10:15 AM
My crew and I have decided that once we all get back ito riding (new boat in about a week), we will occasionally have a "switch" day, where we will all ride switch for most of the day. Also trying to get a "naked" day. Wish me luck!!
01-07-2005, 2:22 PM
If you can get to a cable park and just go switch for the day. Maximum water time. When you can surface 180 both ways, then bunny hop, then bunny hop back, then do each switch really quickly etc etc, till you dont notice any difference either way.
01-07-2005, 5:43 PM
Buzz, Too funny! Please don't post those pics hahaha
01-08-2005, 5:50 AM
a really good way is if you have a slalom course you can use, just go through it switch. Its gets you really used to using your edges switch.
01-08-2005, 7:55 AM
Once you get up out of the water switch 2 switch as quick as possible than ride like that for awhile until you get your balance. It comes with time.
02-03-2005, 11:53 AM
i just try and ride switch as much as possible each time i go riding. i do alot of switch runs also
02-03-2005, 2:22 PM
I agree with skating switch. If you're not used to skating, buy a longboard skateboard, they are much easier to ride. This has helped me immensely, plus it's fun to bomb hills and cruise around in the winter when it's too cold to get in the water.
02-03-2005, 3:37 PM
I got this from Kyle Schmitt... Start every set with warm-up including 4 edges (reg/switch x heel/toe), 4 surface 180s (inside-out/outside-ine x heel/toe) and wake crossings.
02-03-2005, 7:57 PM
I agree with Chris, When the water is too choppy to ride, instead of calling it a day, we will usually practice riding switch all day during in the rough conditions. Then when you get back to smooth water, switch is no problem.
02-09-2005, 11:14 AM
Hey, I had the same problem getting used to riding switch. What does help a tremendous amount is to set up your bindings duck footed, so that both toes point outwards. that way you always have your lead foot in a fairly natural position... exept it could hurt your ankles if the tounge of the binding twists, and you ride hyperlite spin bindings like i do. when i ride switch, the top corner of the sides is fairly sharp, and it will cut into my ankle literally digging a hole. it sucks... but yeah just adjust your bindings a little to make it more comfortable
