Here are some things I do before I turn the ignition key the first time of the season. Charge and install battery, check electronics, clean boat, make sure all your engine drain plugs (petcocks) are in and tight and inspect hoses / belts. Early in the season after a couple of rides, I will change fuel filter, oil / oil filter, and impeller. You could do the fuel filter and impeller right off the bat, but you will need to run your engine to warm up the oil before you can change it.
