I have an 07'Moomba. It came with the worst ballast system ever. Now for the 09' boats, they came with a better system. Does any one have a suggestion on a pumps that I can use. I did change out the system that I had. This is what I did. I removed the single 500GPH pump and installed 3 new 1200GPH Tsunami pumps, one for each bag. Now the problem. In our boats, we have the sprinkler valve system. I used the valve to open and close the water flow. Well this weekend, I tried the new system. The valve system is crap. water was spitting out of the valve. There has been a few thread about removing the internal spring on the valve. The water flow increased tremendously. Great right, not really. Now the spring are out, the water flows freely into all the back when the boat is in motion. I think that I need to redo the system again. I was looking at the Jabsco pumps. There are two that I light. The first is the reversible at 9gpm or 540gph. Or the single way at 6.3gpm or 378GPH. I really like the Tsunami pumps. They really pump a grip load of water. Is there anything that I can use as a valve to solve my problem or do I need to go back to the drawing board. Tazz
