I have a '93 with the LT-1 and I run about 900 lbs. in back and 300 lbs. up front plus people and it takes no time at all to plane out. I have the 3-blade prop on mine and it does just fine. Unless you are going to put 2000 lbs. plus in your boat, the 3-blade should be just fine. And no matter what weight you have in the boat, the LT-1 will have plenty of power.
