03-12-2007, 10:21 AM
anyone have any good tips for cleaning vinyl seats? after a hard summer my seats don't look to good, even after a detail there is stuff that didn't come off
03-12-2007, 10:23 AM
Magic Eraser
03-12-2007, 11:19 AM
If you use the Mr. Clean Magic Eraser have a clean towel to wipe the excess off right behind Where you have just wiped
03-12-2007, 11:22 AM
i tried the eraser and it not getting everything
03-12-2007, 11:32 AM
Hydrogen peroxide
03-12-2007, 11:42 AM
Magic Eraser, a little 303 cleaner, lots of rinsing. Then treat with 303 protectent to keep it looking new!
03-12-2007, 11:50 AM
i like the 303 cleaner for daily dirt. for stains, you may need a little more
03-12-2007, 11:59 AM
03-12-2007, 12:44 PM
where does one get 303 cleaner? have to order it online?
03-12-2007, 1:35 PM
I use the magic erasers with 3M's vinyl cleaner nad restorer.
03-12-2007, 2:28 PM
I want to get some of that Nad Restorer that Adam uses. My nads need restoring in a bad way.
03-12-2007, 3:22 PM
I got my 303 stuff from Auto Geek! I could not find it locally. http://www.autogeek.net/303.html
03-12-2007, 6:08 PM
I use fantastic and a medium scrub brush to get into the poors of the vinyl.You need to follow close behind the scrub brush with a clean towel. Follow up with 3m vinyl protectant.
03-12-2007, 6:39 PM
the best cleaner is yacht bright will not take the protective film off of your seat. Then put on 303
03-12-2007, 7:36 PM
I have also had good luck using a steam cleaner, like a steam shark or steam mouse and a brisk scrub brush.
03-12-2007, 9:02 PM
We keep our boat outside over the winter. I used a magic eraser on it last weekend while getting it ready for spring. I was shocked at how well it worked. Boat interior looks almost new. I wiped up excess right after using the eraser.
03-13-2007, 4:46 AM
You might also try Oxy Clean in the granular form... Mix it with a bit of water and make a paste. Use a small scrub brush and wipe clean with soft towel... then 303!
03-13-2007, 8:24 AM
Wanted to redo my vinyl, so went to get a price of $2400.00. The owner told me to get some vinyl shampoo, clean and condition what you have then we'll see what you need. Went to local detail supplier and picked up a gallon for $11.00,(Mark V product). Dilute it at 40 to 1, reccomended, or less on the tough dirt. After a couple of hours in the boat i now saved my $2400.00, i only have to replace a strip on the motor cover that is cracking. This stuff is amazing!!! 1993 MC, origional interior, with 1200 hrs.
03-13-2007, 8:48 AM
Scott has it... "magic eraser" and 303. I've never seen anything working better than this combo.
03-13-2007, 10:39 AM
i just found the best solution i believe. Oxyclean with woolite. its for carpet so it shouldnt mess up your stitching. spray it on and scrub it with a STIFF plastic brush. with the stiff bristles you dont have to push on it at all really, and it gets into the lil grooves. then just wipe it off. i used the magic eraser and wasnt impressed really at all. i couldnt get the deep dirt out with it, but the stiff brush and oxy it came right out, and my vynil was nasty and i have never seen vynil so white now!
03-13-2007, 12:10 PM
Kevin, Oxyclean I would stay away from. It does work awsome but after a summer of sun you will see why to stay away from it on vinyl. Now on the other hand the woolite part works great with a touch of very mild dish soap and the magic eraser. Cleans to brand new status. Use a good vinyl conditioner after and keep up on the gerneral cleaning each time out.
03-13-2007, 12:50 PM
Another vote for the magic eraser. Follow the magic eraser up with a clean towel, and then finish it off with some 303. Works great.
03-13-2007, 1:31 PM
Olny bad thing about the Magic Eracer is the $$$. Other than that, it is a great product. But do try the viayl shampoo, at $11.00 per gal. I did my interior and the gallon is still full.
03-13-2007, 4:35 PM
you were kidding about the price of the magic eraser right? 1.50 for two is cheap!
03-13-2007, 4:36 PM
so whats it gonna do to the vinyl? it also has 3m shampoo, polish and the sun screen stuff, i think it will be fine.
03-13-2007, 10:07 PM
"Scott has it... "magic eraser" and 303. I've never seen anything working better than this combo."... I have. Malco Plastic and Leather Cleaner and then 303. And the Malco cleaner won't hurt the thread that your upholstery is held together with over time like household cleaners can.
03-14-2007, 4:14 PM
Elbow Grease!
03-14-2007, 6:20 PM
Went to auto geek for the 303. Do you get the vinyl cleaner or protectant to follow the magic eraser?
