Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old     (davidhep23)      Join Date: Feb 2007       06-24-2007, 4:57 PM Reply
I'm trying to replace the prop on my vlx. For some reason I can't get it on all the way flush on the shaft. It like about a quarter inch being flush. Its not on backwards either. Can it have anything to do with the torque pin not being in the right position. Any help would be appreciated.
Old     (bftskir)      Join Date: Jan 2004       06-24-2007, 5:12 PM Reply
you could have the key in too far...
did you tighten the bolt? and it did not "flush up"?
Old     (davidhep23)      Join Date: Feb 2007       06-24-2007, 5:20 PM Reply
I tried to tighten the bolt, but it didn't move it.
Old     (05mobiuslsv)      Join Date: Apr 2006       06-24-2007, 5:24 PM Reply
The key insterts into a groove in the shaft, make sure it's in the grove properly. You will see the indentation on the shaft, the key should fit totally into the indentation. Also make sure the key hole is lined up with the key. If all this is right you should have no problem.
Old     (bftskir)      Join Date: Jan 2004       06-24-2007, 5:51 PM Reply
you may have to try harder
Old     (wake_upppp)      Join Date: Nov 2003       06-24-2007, 6:53 PM Reply
Take the prop back off, and slide it up the shaft with NO key, mark how far up the hub of the prop goes on the shaft, then do it with the key and if it doesen't go all the way back to the mark, grind/sand key height until it does.
(Message edited by wake_upppp on June 24, 2007)
