when you say there's a crack along the bottom, is it possible they just need to be tightened down? they do wear out over time, 5 years in salt water. can you see the crack? that's the thick part of the riser, strange place for a crack. they usually warp there when the engine is overheated. i'd get some new gaskets and take the manifold off to take a look. if they're all gunked up inside or there is a crack, time for new ones. if not, i'd tighten them back down with the new gasket and see what happens. don't run too long like that, water can get into your engine from the exhuast that way.
