Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 11, 2007
Old     (medross)      Join Date: May 2004       06-30-2007, 9:46 PM Reply
I have an 04 X-30. My Port side ballast was not working at all. The light on the switch does not come on whether you turned it to fill or drain. The other two were working fine until today, we went out and filled the starbird and middle locker ballast to do some surfing and now none of them work. So now I have two full and I can't drain them. Are there any fuses anywhere to check? Where do I start?
Also is it oaky to drain them when the boat is not it the lake?
Old     (medross)      Join Date: May 2004       07-01-2007, 7:16 AM Reply
Nevermind, I found the problem.
Old     (joec08)      Join Date: Jul 2007       07-04-2007, 8:10 AM Reply
mike,I have the same problem on my x-30,how did you fix it .thanks joe
Old     (reinle)      Join Date: Sep 2005       07-04-2007, 1:20 PM Reply
we have an 06 x-30 and the fuse box is tucked up in the rear left locker
Old     (medross)      Join Date: May 2004       07-05-2007, 8:36 PM Reply
There is a circuit breaker underneath where the ballast switch is. Make sure the pumps are off and then push the breaker button and that should do it.
