quote:1. My XTi with the kit lens 17-55 EF F4/5.6 does not appear to take as sharp a photo as my $130 canon 5 MP point and shoot in many situations.
Most likely due to operator error.
I use the 70-200L and it's a great lens for wakeboarding. 200mm is more than enough zoom for shooting from the tow boat. For boarding shots you will be shooting at fast shutter speeds in most cases so there's really no point in paying for IS if this is what your using the lens for.
Keep in mind that you won't be zooming in to 200mm unless you want a guy in the shy shot. When I'm shooting from the tow boat I usually am around 70 to 85mm. If you zoom in to tight you loose all perspective.
You can pick up the 70-200L f/4 for around 600.00
The Canon L glass holds it's value fairly well too.
Remember that your not using a point and shoot camera any more and now you are a big factor in how the photos come out.
My advise is pick up your camera and use it as much as possible so you understand what all the settings do and how to change them quickly.
