Old                08-15-2003, 12:03 PM Reply
Hey, I've got a problem with my Raley. Although I have landed a couple I am still doing something wrong. Most of my failed attempts have been because the board would rotating durring my extention almost like a Kryp.
Any thoughts on how I can stay more balanced?
Old     (mvda)      Join Date: Dec 2002       08-15-2003, 12:05 PM Reply
Look at the boat while in the air.
Old     (sdboardr99)      Join Date: Aug 2001       08-15-2003, 1:27 PM Reply
If your back foot is rotating above you, then put a little more weight on your front foot. A raley requires you to hit the wake with more weight on your front foot than normal.
Old                03-02-2004, 6:52 PM Reply
If you are almost pulling a Kryp...make sure that you are pulling the handle down toward your leading leg. If you have to pull the rope kinda past your hip towards your back to get a little more leverage in that direction.
That should stop you from rotating switch.
