Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through January 11, 2007
Old     (weekend_wakeboarder)      Join Date: Jul 2006       11-07-2006, 3:26 PM Reply
ok, suppose you take off the fins and the holes are left in the board, i am assuming that water can get through the board and also into the core?......is there a chance that this may happen?
Old     (thane_dogg)      Join Date: Jun 2002       11-07-2006, 3:27 PM Reply
if it is a balsa wood core, or some other composite core that is porous, the answer is yes.
If it is a foam core, which most boards are, it is closed-cell foam, and it will not absorb water.
Old     (sunsport)      Join Date: Sep 2002       11-07-2006, 4:14 PM Reply
Actually even the balsa cores you are fine. The balsa is only in the center of the board. It does not extend out to the edges or where the fins are.
Skiing made me board,
Lyle
Chrome Dome
Old     (garman)      Join Date: Feb 2005       11-07-2006, 4:16 PM Reply
Put a piece of electrical tape across the holes.
Old     (otiswunguy)      Join Date: Apr 2002       11-07-2006, 5:05 PM Reply
I like the rooster tail effect, it makes me feel like I am riding really fast!!!!
Old     (7890303)      Join Date: Sep 2006       11-07-2006, 7:26 PM Reply
silecone
Old     (maestro)      Join Date: Jun 2001       11-07-2006, 7:29 PM Reply
Candle wax
Old     (denverd1)      Join Date: May 2004 Location: Tyler       11-07-2006, 7:30 PM Reply
chewing gum
Old     (denverd1)      Join Date: May 2004 Location: Tyler       11-07-2006, 7:31 PM Reply
or silly putty.. whichever you have more of
Old    zcarnage            11-07-2006, 7:32 PM Reply
If your concerned, swab the hole with a little 2 part epoxy. Typically, there should be a block of ABS plastic inserted into the core, (foam or wood) so it shouldn't be just bare core material unless there is damage or a delam issue, or you drilled your own fin holes... which you can do with balsa cores because the wood is end grain, but generally not the best idea...
Old     (jarrod)      Join Date: May 2003       11-07-2006, 7:36 PM Reply
Th new Transcend whistles with the fins out.
Old     (thane_dogg)      Join Date: Jun 2002       11-07-2006, 9:05 PM Reply
Lyle - the dna core hyperlites had the wood come all the way to the edges and tips; however the lf ultra cores were not constructed this way.
