We are in the process of an old school budget build and need some help with a prop. The boat is an 86 Supra Sunsport, with 351 PCM. I am told it's a 1" shaft, LH rotation. Factory is supposedly 13X13. The local dealer says to add weight we should only change to a 13X12 3-blade. I was always under the impression that a 4-blade was the way to go for a wakeboat. Since this is not a cheap proposition so I appreciate your input. Thanks! Matt
