LOL! Ed, ours could actually be ridden. You can bend the rocker in a few ways, but considering it's winter and you may not be riding in a while, after you cut the outline, lean it at an angle for a few weeks. It will sag and take on the rocker. If you are in a rush, you can steam it. To steam it I'd just block the nose up using a piece of 2x4, or make a block from the offcut of the plywood. Using anything heavy enough to cause the plywood to sag, then get some boiling water with steam under it.
