Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 08, 2008
Old     (treycleaton)      Join Date: Mar 2005       06-07-2008, 12:56 PM Reply
My thermostat was stuck as one issue in my motor overheating (my impellar was also fried) A mechanic friend that used to service Mercruisers claims that it will be fine w/o a thermo. Anyone else doing this? I was told that it simply keeps the motor temp within a certain range, and that it should cool just fine without it. I don't want to screw anything up. Thanks
Old     (pwningjr)      Join Date: Apr 2007       06-07-2008, 1:48 PM Reply
The thermostat keeps the engine at a certain temp for a reason; the tolerances can get way off if it runs way too hot or way too cold for a long time (in this case, cold) and you would lose a lot of power, not to mention I'm pretty sure its not good for the life of the engine.
CCFan post
Old     (seaswirlmike)      Join Date: Nov 2003       06-07-2008, 1:51 PM Reply
well it wasn't a mercruiser but on our first boat (seaswirl) it would never warm up. come to find out the thermostat was stuck open, basically the same as not having one. never had any issues performance wise. that was my experience with thermostats in boats
Old     (rallyart)      Join Date: Nov 2006       06-07-2008, 1:53 PM Reply
There are instances where you can run without a thermostat but a start and stop boat would not be one of them. Normally a restrictor plate is put in, in place of the thermostat. It almost every situation using a thermostat is far superior to not having one.
With out one it will cool just fine, like your friend said, but it will not warm up well at all. That means that you get less power, worse fuel consumption, and more engine wear. Because it's running without the temperature control you get less consistent power for starts and speed control.
Use a 160 degree replacement of good quality. If you had a cooling issue with lack of water flow past the thermostat you could put a 1/16"hole, or smaller, in the thermostat metal to the side of the valve. That ensures flow past it so it will open at the right time. You will be surprised how much longer it takes to get to operating temp with even a hole that size.
Old     (murphy_smith)      Join Date: Dec 2005       06-07-2008, 1:57 PM Reply
Common sense says use a thermostat.
Old     (rmcronin)      Join Date: Aug 2002       06-07-2008, 5:25 PM Reply
I ran mine without one while waiting for a new one. You will burn MUCH MORE FUEL. Enough said.
Old     (treycleaton)      Join Date: Mar 2005       06-07-2008, 6:43 PM Reply
Thanks guys, I'm ordering one tonight
Old     (1boarder_kevin)      Join Date: Mar 2007       06-08-2008, 8:10 AM Reply
Without a thermostat, you will lose power and use more gas.
