LESSONS LEARNED ARE.
(1)only use paint on the core then lam , never paint then hot/glosscoat because of fear of fisheyes.
(2) make sure to move your project inside when bad weather shows up , i did not think i would get rain mist sprayed on the board after a hotcoat but i did.
(3) get ricepaper artwork in before you lam , and do not install as part of hotcoat , you will just to do it again to burry the paper.
i used 2.5 qt of epoxy mix on this project and should have used about 1.5 total . with all of the rework i had to do these were lessons learned,
