That usually means you are either flattening out at the last minute, or absorbing the wake with your knees. Maybe both. Also, what rope length are you riding at? You might need to shorten it at first, for some people 55' others 60'. Try taking a smaller cut, like maybe 10' or 15' outside, and then coming in. It's really easy to flatten out when you approach with too much speed. Taking a smaller cut will force you to cut hard and edge all the way through the wake, just make sure to "stand tall" at the wake, meaning straighten out your legs and don't let you knees bend as you hit the wake. The best thing to do is watch video in slow motion of your riding. You should be able to spot what you're doing wrong, and if not either post the video or compare it to a pro and see what you're doing wrong.
