Taco you're getting close! Go back and replay it, then stop it RIGHT when you go to do the surface 3 - you are turning the board out and away from the wake. You need to initiate the 3 by starting a turn up and into the wake. If you have to bend to drag your hand, bend at the knees, not at the waist. Also, on the P5, you don't need a great amount of speed to initiate the rotation. Get into the location to start the 3 and practice turning up into the wake and dragging your hand. You'll probably float out the back, but you'll feel in control of the rotation. Once you have that down, add just a little speed (1/2 a board length) to start the 3. You're close!
