Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (duffmangt)      Join Date: Jan 2008       06-27-2008, 8:20 PM Reply
I have a mastercraft x-2 07'...a lil more than a week ago we hit concrete with our prop putting the boat up and wrecked the prop. we took it in got the prop fixed put the prop back on and are back in buisness. but after the first couple of times out i started to notice a wierd vibration when we go from dead stop to getting on to of the water. it didnt happen the first like 2 times after we had the new prop out but now its pretty constant. the wierd thing is is that the x2 drive much better now >> its so much easier to steer but it worries me about the vibrations...we've checked and everything is on right/tight...any tips? trying to avoid taking it to MC due to ridiculous wait times!
Old     (wake_upppp)      Join Date: Nov 2003       06-27-2008, 9:08 PM Reply
Either the prop is not seated right or you bent the prop shaft too, during the tangle with the concrete.
Old     (wakeslife)      Join Date: Jul 2005       06-27-2008, 9:34 PM Reply
if you think you might have bent the prop shaft, take it in, cause you could cause much greater problems throwing the rest of the drivetrain out of alignment.
Old     (bac)      Join Date: Feb 2008       06-27-2008, 9:44 PM Reply
When we trashed ours, we also bent the strut, it wasn't very much, but when you looked really close, you could see it. Is your strut ok? I would check that shaft too. If its bent, you'll wallow that bearing out
Old     (1boarder_kevin)      Join Date: Mar 2007       06-28-2008, 7:38 AM Reply
I second everything else said. get it to the dealer so they can check out the shaft, strut etc. you got issues and it will damage your boat as it is now.
Old     (duffmangt)      Join Date: Jan 2008       06-28-2008, 2:41 PM Reply
alright thanks guys, hopefully ill get it in there tuesday when theyre open again
Old     (denverd1)      Join Date: May 2004       06-28-2008, 2:43 PM Reply
have it checked to be sure. long-term, you can damage your tranny if thingsg aren't lined up just right.
