Old     (hawk22)      Join Date: Jul 2006       04-27-2009, 11:00 PM Reply
I'm new to the automatic ballast. Got an 04 Moomba Mobius with the center sac. fill switch works and pump turns on, but no water is going in the bag. I found the incoming water valve to the pump and that is open as well. any suggestions?
Old     (bill_airjunky)      Join Date: Apr 2002       04-27-2009, 11:44 PM Reply
So is any water pumping at all? Pull the hose & turn it on. Might be time to open the pump & check the impeller's condition.
Old     (spencerwm)      Join Date: Feb 2009       04-28-2009, 9:24 AM Reply
Like Bill said it is time to start following the flow. Start at the pump and make your way down the line. Usually it is either the Rule pump or some sort of blockage in the line. The process shouldn't take too long. Good luck.
spencer@wakemakers.com
(Message edited by spencerwm on April 28, 2009)
Old     (moombadaze)      Join Date: Dec 2003       04-28-2009, 9:35 AM Reply
Try getting the boat on plane 1st to get water started
Old     (eric_z)      Join Date: Jan 2008       04-28-2009, 7:53 PM Reply
I had the same problem last year you just need to get the boat moving a little faster to get the pumps to prime....
Old     (eric_z)      Join Date: Jan 2008       04-28-2009, 7:55 PM Reply
Get it moving faster and prime the pumps
