Old     (jcv)      Join Date: Oct 2005       06-19-2008, 12:25 PM Reply
So I dinged up the ol' prop a little last night, and need to take it in for a re-shape. However, the bad boy won't budge, prop-puller and all. I'm officially stumped.
Playing amateur mechanic a little: it looks like the inner pin may have shifted, somehow catching on to the prop.
Old     (peachman)      Join Date: May 2004       06-19-2008, 12:40 PM Reply
Suck the prop puller down as tight as you can, take a rubber mallet and hit the front of the prop. Give it a couple good smacks and it should pop loose.
JT
Old     (wakejunky)      Join Date: Apr 2002       06-19-2008, 12:57 PM Reply
Worse case is to heat up the prop and then start whacking.
Chris
www.wakejunky.com
Old     (rallyart)      Join Date: Nov 2006       06-19-2008, 12:59 PM Reply
Propane torch to heat the prop while the puller is tight might also help.
Old     (rallyart)      Join Date: Nov 2006       06-19-2008, 1:00 PM Reply
Wakejunky types faster than me...
Old     (jcv)      Join Date: Oct 2005       06-19-2008, 1:06 PM Reply
I'll try the mallet...the torch I don't have access to.
Old     (guido)      Join Date: Jul 2002       06-19-2008, 1:25 PM Reply
You can get a propane torch at any hardware store for less than $20.
Old     (grant_west)      Join Date: Jun 2005       06-19-2008, 1:36 PM Reply
Yup the Torch is the Ticket.
When my GOOD buddy Caesar ran my boat on shore and DESTROYED my $400 ACME prop the only thing that got it off was a torch. We took it to this Hillbillys shop and he took a torch to the prop and about 3 or 4 hits with the mallet and it came right off. The prop looked hammerd. I handed it to him and said Her's your new prop.
2 Weeks later he handed me back my dammaged prop. It looked like brand new. OMG all is forgiven.
P.S I a havent tryed the repaird prop. (its my new spair) If I put it back on and it vibrates then Im comming after you Caesar !!!!!! LOL
Old     (olskooltige)      Join Date: Mar 2007       06-19-2008, 3:00 PM Reply
BFH is the ticket.
Old     (boarditup)      Join Date: Jan 2004       06-19-2008, 7:05 PM Reply
Use a steel hammer - a 2 lbs. or hand sledge. It has to ring - vibrate the prop off. Try it before the torch.
Old     (kana12)      Join Date: Jan 2008       06-19-2008, 8:03 PM Reply
torch it damn it !!
