I'm adding another bag and pump for the front. Quick question...when using a reversible pump, does water fill and drain from the same thru hull? I'm sure this is a stupid question, so forgive me. When using with a ProX sac, I only should have the hose going into one connection right? And use one connection for a vent line? You only use all three connections on the sac if you have separate pumps for filling and emptying, correct?
