Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (spherren)      Join Date: Aug 2005       08-17-2009, 8:47 PM Reply
I took out my oj prop this weekend. One blade is now missing, can this be repaired? Bent my strut and gell coat damage. Really sucks!Upload
Old     (ord27)      Join Date: Oct 2005       08-17-2009, 9:18 PM Reply
yup
did the same thing to mine
we hit a submerged stump doing about 20
didn't shear off the blade like that, but bent all 4 of them pretty good
took a few weeks to get fixed
over $5,000 in damage
shaft, strut, prop, lots of gel coat and some fiberglass work
boats now as good as new.....can't tell it was ever damaged
thank goodness for good insurance!
Old     (spherren)      Join Date: Aug 2005       08-17-2009, 9:37 PM Reply
can the prop be repaired?
Old     (cavlxenvy)      Join Date: Aug 2007       08-17-2009, 9:38 PM Reply
I seriously doubt that can be fixed. With all the labor involved, it would be just as easy to get a new prop.
Old     (05mobiuslsv)      Join Date: Apr 2006       08-17-2009, 9:45 PM Reply
I don't think a repair shop would touch that.
Old     (ord27)      Join Date: Oct 2005       08-17-2009, 11:04 PM Reply
your insurance will buy you a new prop
(Message edited by ord27 on August 17, 2009)
Old     (hudd007)      Join Date: May 2006       08-18-2009, 12:19 AM Reply
definitely cannot be fixed.
Old     (ixfe)      Join Date: Aug 2008       08-18-2009, 12:28 AM Reply
You did $5k in damage to your boat... and you're worried about the prop?
Old     (pri3st)      Join Date: Aug 2007       08-18-2009, 12:49 AM Reply
I'm pretty sure that the blade that is missing cannot be repaired.
Old     (spherren)      Join Date: Aug 2005       08-18-2009, 7:54 AM Reply
just thought I would have it repaired for a spare.
Old     (bmartin)      Join Date: Jan 2007       08-18-2009, 8:02 AM Reply
Need an office decoration???? Besides scrap, that is all you can do with that prop.
I'm kind of amazed there isn't significant damage to the other blades. Good luck patching the rest of the damage up and yes insurance may be able to help you out.
Old     (johnsvt)      Join Date: Dec 2006       08-18-2009, 8:19 AM Reply
that prop is done for
Old     (mastercraft1995)      Join Date: Nov 2002       08-18-2009, 8:47 AM Reply
What did you hit?
Old     (spherren)      Join Date: Aug 2005       08-18-2009, 9:05 AM Reply
I never saw what I hit, it was dark in about 100ft of water on Flathead Lake in Montana. With the way it looks and the scuff on the bottom of the boat, it appeared to be a log.
Old     (hatepain)      Join Date: Aug 2006       08-18-2009, 9:54 AM Reply
Is that water or bubbling in your gel coat? I would think a prop shop would be concerned about liability slapping another vane on that prop.
Old     (spherren)      Join Date: Aug 2005       08-18-2009, 9:56 AM Reply
Water, took a good chunk out above the prop and then the strut is bent. The vibration caused the
gel coat to crack out around the strut. Im going to take out the shaft and have it checked.
Old     (spherren)      Join Date: Aug 2005       08-20-2009, 11:29 PM Reply
So I took out my shaft, it has a slight bend to it and I am going to have it straighten tomorrow. The strut does not look bent at all. I have measured it from side to side with a square and some tricky measuring and there is less than 1/8 inch difference. What does everyone think
Old     (boarditup)      Join Date: Jan 2004       08-21-2009, 7:25 AM Reply
Replace with new. I never trust fatigued metal in a critical application. It needs to be aligned by someone who knows how to get it right - someone experienced.
