Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 06, 2007
Old     (louie)      Join Date: Jun 2006       07-17-2007, 4:01 PM Reply
I had to reset my perfect pass and I didn't check my #'s before I reset it. I've lost three days of riding do to the problem. I just can't get the KDW NN #'s back to the way they were. It surges up to 5 miles an hr. I've emailed perfect pass and I've tried 185/120,120/100. I have an 05 MB B52 V23 and we usually run 2500 lbs of ballast and 5 adults. Any advise would help.
Old    sandvign            07-17-2007, 10:28 PM Reply
Also wondering the same thing. Just got Perfect Pass in a '99 Maristar 230 with LT-1 engine and Acme 1235 14.5x14.25 prop. 95% of the time the boat is run with 4500 pounds of water. Right now the Perfect Pass really surges through turns and doesnt even keep speed that great. At least not $1500 great. Anything you guys know that could help me get it dialed in?
Old     (alans)      Join Date: Aug 2005       07-18-2007, 5:09 AM Reply
B52V23, I have some good numbers for V23s. Do you have the ZR6 or 330?
Old     (cyclonecj)      Join Date: Jul 2001       07-18-2007, 10:21 AM Reply
Make your KDW larger for larger speed changes each time the system makes a control move. I would go higher than 185 until it controls speed better. With the NN, the smaller it is the more often it will average the paddle wheel pulses and make a control move.
So, by making KDW larger and NN smaller, you make the system try to control speed more aggressively by making bigger speed changes more often.
Start with a KDW of 225 and an NN of 70, see where that gets you. If it takes a long time to get to the speed setpoint but does not overshoot (much), make KDW bigger. If it is twitchy and hunts around the setpoint, make NN bigger and/or KDW smaller.
If you run with different loads, i.e. more or less weight and people, you may have to adjust these values.
Old     (styk33)      Join Date: Aug 2004 Location: NorCal       07-18-2007, 11:17 AM Reply
Psyclone, thank you for the explanation. I had the NN backwards. Mine is only off by .3mph, but used to be within .1.
Old     (louie)      Join Date: Jun 2006       07-18-2007, 3:27 PM Reply
Alan Slabaugh, I have a PCM 330, whatever you can help me with would be great because I don't know what my numbers were. It was perfect for so long.
Old     (h2oaddiction)      Join Date: Aug 2007       08-02-2007, 10:17 PM Reply
I am having the same issues on my '06 V23 Team. We've tried multiple settings via Randy and Gary at PP and three different prop configurations and still can't maintain speed when a rider loads the line. Any help would be greatly appreciated. I also have the PCM 330. The local PCM tech (Correct Craft dealer) said they are having issues with the DBW system too. Thanks again.
Old     (migs)      Join Date: Aug 2006 Location: SF Bay Area       08-03-2007, 7:45 AM Reply
Use your RPM mode = 0 fluctuation.
Old     (h2oaddiction)      Join Date: Aug 2007       08-03-2007, 8:53 AM Reply
Thanks. That's what the Correct Craft dealer suggested, but we haven't had a chance to try it. It just would be nice if it all worked properly. Thanks again
